Author Topic: 20V Tech Reference  (Read 2636 times)
20V Tech Reference
« on: February 13, 2014, 01:03:29 PM »
Re: 20V Tech Reference
« Reply #1 on: February 13, 2014, 06:15:44 PM »
MEGASQUIRT!!!!: http://forums.club4ag.com/zerothread?id=11048
I have megasquirt configurations that you can use as base maps for 4agze and 20v.
This one has been downloaded 42 times in the last 2 years.
https://app.box.com/shared/w8biflba8c
I have emissions maps, performance maps etc..
This should be a link to about 50 screenshots of MS configuration if you ever wondered what it can do.
https://app.box.com/shared/supjv2ay2i
« Last Edit: February 13, 2014, 06:29:46 PM by twincharger »
« Reply #2 on: February 13, 2014, 10:32:42 PM »
i will selfishly request any and all info or write ups on ignition setups for rwd 20v.  I have a general direction i want to go, but i don't really have anything sorted yet
« Reply #3 on: February 14, 2014, 10:48:09 AM »
You have a standalone to use on your 20v.  I'm assuming it has 4 ignition output wires to trigger 4 coil packs.
I'm considering building an ignition multiplexer that takes output from the stock ECU and will distribute that output to the proper coil so you can run COP with the stock ECU, Stock distributor base, no cap, rotor, igniter or ignition wires.  I need to gather Toyota plugs to make it plug-n-play.   I will have a blacktop to test it on in a few months.  I could probably make it work on the 16v too.
« Reply #4 on: February 14, 2014, 03:44:26 PM »
I do. It came with a harness for a blacktop to run on 4 LS coils.  It's also designed for boost as I just learned.  Has some AEM goodies and sensors.
I'd rather stay Toyota and use 1zz cops.
I still need to see what all I need.  I haven't had a motor for so long I haven't bothered to grasp the concept at all.  I should probably start
« Reply #5 on: February 15, 2014, 08:12:09 AM »
Chris, I am also interested in going coil on plug. Let me know when you piece it together.
« Reply #7 on: March 27, 2014, 09:42:43 PM »
found this on a recent waterpump hunt.
http://www.tunemytoyota.com/forum/showthread.php?t=2715
