Author Topic: Swapping a 4age into an sr5 with engine harness only.  (Read 2751 times)
Corollasr5
« on: May 30, 2014, 02:58:05 PM »
So I pretty much have a complete 4age motor with the engine harness as well, but no other gts harnesses. How much work am I looking at to swap it in my sr5? Anyone done it this way? I was thinking of running an inline fuel pump.
Re: Swapping a 4age into an sr5 with engine harness only.
« Reply #1 on: May 30, 2014, 07:13:44 PM »
Inline pump or not you'd still need a return line plumbed somehow? Amongst other things...
Here's some good reading:
http://www.hachiroku.net/sr5togts
http://www.86garage.com/forums/viewtopic.php?f=2&t=4257
« Reply #2 on: May 31, 2014, 09:59:58 AM »
i have both dash harness and body harness for gts. would make it easier...
NoMasHondas
« Reply #3 on: June 13, 2014, 02:59:54 PM »
You don't need the gts dash or body harnesses, it doenst make it easier, because you have to take out the dash and the interior. All you need is the gts engine harness, and wire it in, I can help with that. The 4age install is straight forward.
« Reply #4 on: June 13, 2014, 07:26:09 PM »
oh yeah completely forgot about the way you did it. lol only thing i saw was $$$$$  ::)
Corollasr5
« Reply #5 on: June 19, 2014, 01:06:47 PM »
I'm assuming I'm gonna need gts fuel lines or no?
« Reply #6 on: June 19, 2014, 03:42:07 PM »
Gts fuel lines and tank would be easiest but you can go external fuel pump with sr5 tank. Twincharger has this on his sr5 twincharged setup.
overspool
« Reply #7 on: July 07, 2014, 11:25:16 AM »
I have an external pump and am using the SR5 tank and lines.
