Author Topic: Need electrical help. Free beer!  (Read 3285 times)
Crono0001
« on: July 28, 2014, 08:21:50 PM »
In the process of installing these fog lamps, I accidentally shorted my passenger JDM bumper lights. I've tried to find it for the past two hours but I give up.
Anyone with electrical expertise wanna help? Beers/food/joyride on me.
Porsche Boxster 986 3.8
Toyota Corolla AE86 F20C
Mazda Miata NA8C
Re: Need electrical help. Free beer!
« Reply #1 on: July 29, 2014, 07:34:40 AM »
Check fuses.
Toywagon82
« Reply #2 on: July 29, 2014, 10:06:18 AM »
X2^
Can we still have what you offered?lol
« Reply #3 on: July 29, 2014, 11:24:52 AM »
We helped! :3
Seriously though check all the fuses. Old cars (like houses) are super annoying. Too many unrelated things on the same circuit. I remember in my 240 if there was no bulb in the dome light the radio wouldn't work. Also, if there was a fuse in the power window circuit, the battery would drain. Pull the fuse and the drain went away but the windows still worked.
Crono0001
« Reply #4 on: July 29, 2014, 12:30:34 PM »
It's not car side.  Power and ground from car are fine.  It's from the light cluster
Mazda Miata NA8C
« Reply #5 on: July 29, 2014, 12:59:36 PM »
Is the bulb burned out then? If you have power and ground all the way to the light there's not much else it can be.
Crono0001
« Reply #6 on: July 29, 2014, 02:08:00 PM »
It isn't the bulbs.  It's the wiring.
The wrong light turns on at the wrong moments.  Definitely a short in the cluster.  Can explain better in person.  Free beers!
Mazda Miata NA8C
« Reply #7 on: July 29, 2014, 08:06:19 PM »
How did u wire the fog lights in? Assuming u tapped into the same circuits as the bumper lights, where/how'd u splice into those wires? The fog lights are gonna have more of an amperage draw than markers FYI. They should be on their own separate circuits with a separate fuse and relay, perhaps using the markers as a trigger for the relay. (That is, if u want um on all the time.)
Crono0001
« Reply #8 on: July 29, 2014, 10:46:44 PM »
I spliced power and ground straight into the bumper lights.
I know I have a short somewhere on the bumper lights because I just blew a fuse to the parking and rear lights :(
Mazda Miata NA8C
« Reply #9 on: July 30, 2014, 01:09:45 AM »
Aftermarket fogs should have their own circuit like stated before. Simple solution, remove all connections for fogs and run separate circuit for fogs with a fuse somewhere between. That should fix the problem. If you want it triggeredby a factory source tap into parking lights to a relay like stated above. with our cars tapping into existing power sources is iffy to say the least... just personal experience between cars i have done from older and to recent. You never know what someone else has done 3 owners before you.
« Reply #10 on: July 30, 2014, 07:58:17 AM »
+1^
The marker light switch won't handle fog lights.  Run another wire and a relay.
« Reply #11 on: July 30, 2014, 10:19:45 AM »
Yes, it needs its own circuit. They look cool though!
Crono0001
« Reply #12 on: July 30, 2014, 04:40:24 PM »
Free beers for all.  I fixed it, I hope.
Seems to work now, anyways.
Mazda Miata NA8C
« Reply #13 on: July 31, 2014, 08:52:48 PM »
Ill hold you to it LOL
Crono0001
« Reply #14 on: July 31, 2014, 09:20:03 PM »
Come to BBQ, I will buy several cases.
Mazda Miata NA8C
