Author Topic: Clutch fork. SR5 vs. GT-S  (Read 1751 times)
« on: May 22, 2015, 09:54:47 PM »
Is there a difference.    I'd assume not.   But I do not have both to compare side by side unless I pull a gearbox
Re: Clutch fork. SR5 vs. GT-S
« Reply #1 on: May 23, 2015, 12:34:00 AM »
Doing a little Rock Auto research...
If you look up the part number for an SR5 clutch fork it is a CF132. ($16)
They don't sell clutch forks for GTS models.
So, there must be a difference of some sort, otherwise they would sell the same part for both.
Toywagon82
« Reply #2 on: May 23, 2015, 12:39:52 AM »
Early and late model e7 t50s have two different forks and t/o bearings so it possible
« Reply #3 on: May 23, 2015, 10:26:21 AM »
ClubFag confirmed.  (LIES!!!)
Looks like I'm pulling a gearbox today.
*edit*
Well ClubFag are liars.    There is zero difference between GTS and SR5.
I need a throw out bearing. Not a clutch fork.    Back to waiting for parts.
« Last Edit: May 23, 2015, 03:08:41 PM by SidewaysEightSix »
« Reply #4 on: June 01, 2015, 11:18:34 AM »
At least you clarified that. I always wondered too.
