Author Topic: Sr20det swap question.  (Read 495 times)
RedRolla
« on: June 21, 2018, 01:54:13 PM »
Hey guys, I just got my Sr wiring completed now I have some small stuff to figure out. In my research a while back, I remember coming across reading about using a throttle cable off of an older 240z. Any of you guys know which?
Also, I swapped the Sr into a SR5, did anyone here do the same? and did you use an electronic fuel pump?
Re: Sr20det swap question.
« Reply #1 on: June 22, 2018, 10:09:24 AM »
Rock Auto sells a GTS tank made by Spectre.  It's $130 shipped.  I did a review video on my you tube channel.  Overall quality is good and drops right in.   Then you could go GTS fuel pump bracket and any in-tank pump you'd like. (SR5 is mechanical fuel pump, so either way you have to adapt to a electric pump whether in-tank or in-line.)
As far as the throttle cable, I'm not 100% sure.  I'll text dan and ask him.   I'm thinking a GTS non cruise cable, which is longer, will work.  These can be bought brand new from Battle Garage-RS.
*Edit*.  Confirmed with Haymaker/Dan, OEM GTS cable works!
« Last Edit: June 22, 2018, 10:35:23 AM by SidewaysEightSix »
RedRolla
« Reply #2 on: June 23, 2018, 03:38:06 PM »
Cool bro, thanks for the info :)
