Author Topic: What I did to my toyota today?  (Read 52877 times)
CytoTek
« on: May 03, 2012, 10:05:31 PM »
Pretty successful on the last forum figured I'd start it back up again and kinda update a few today's ago what I've done since the last forum
Got Trd/swift springs in a trade legit as fuck
Got some nrcas camber is legit.
Decided I may have a bent sway bar possibly passenger side control arm doesn't fully drop when jacked up strut stays compressed a little that's the only conclusion I can come to of something with tension
Re: What I did to my toyota today?
« Reply #1 on: May 03, 2012, 10:27:37 PM »
« Reply #2 on: May 04, 2012, 04:19:38 AM »
Finished up getting my new water lines in.  The Mishimoto has a bigger inlet and outlet so I had to make new lines.
braide86
« Reply #3 on: May 04, 2012, 02:26:22 PM »
Changed out my oil catch cardboard to some fresh cardboard. Not really changing something to the toyota, but under it.
« Reply #4 on: May 04, 2012, 11:34:01 PM »
Because of the tight clearance I modified a wrench to tighten down my velocity stacks inside the new box.  13mm wrench+blowtorch+screwdriver
overspool
« Reply #5 on: May 06, 2012, 11:32:54 AM »
I keep looking at my parts piling up and get REAL excited :D
« Reply #6 on: May 06, 2012, 11:24:59 PM »
Drove it home for the first time.  I picked up a hoopty '91 corolla sedan for $1300.  The hunt for another 86 continues.
« Reply #7 on: May 07, 2012, 03:34:27 AM »
Spiffy.  as soon as the paint is dry, I get to stuff it back into the car.
« Reply #8 on: May 12, 2012, 06:09:46 PM »
Turns out the splines on the steering column for the steering wheel hub and shift knob threads on the '91 corolla are the same as the 86.  As a result I swapped over my hub, quick release, steering wheel, and shift knob from the 86, lol.
braide86
« Reply #9 on: May 14, 2012, 11:45:25 AM »
Filled up with some petrol and took a cruise for 22miles.  8)
Tested out my cassette player with some old Rush. Sounded good after a few minutes of scrambled mess. Might need to clean it out.
Phunk Monkey
« Reply #10 on: May 15, 2012, 11:06:02 PM »
It's running?!
Reviving old threads since 1995
« Reply #11 on: May 16, 2012, 07:55:44 PM »
I put the car cover back on....
« Reply #12 on: May 17, 2012, 07:54:29 AM »
Re-mounted my oil cooler after a few coats of paint.  Then measured, cut, and fitted my AN lines.  Taking my car to a couple body shops this afternoon to see when someone can fit me in before the next track day on June 2-3.
Zaxous
« Reply #13 on: May 25, 2012, 03:24:01 PM »
Ordered a RS3871 turbo, a catch can, and 2 12" Fans from Vitaly two days ago. Got notification that the turbo and the catch can are on their way, but the fans are back ordered. Sad face.
« Reply #14 on: May 25, 2012, 11:07:18 PM »
My wife asked me to take the garbage out; I opened my kitchen/garage door and I stopped mid- garage and looked at her... intensely... passionately... then I lightly whispered "baby, gimme more time, we are almost there..."
I teared up.
