Author Topic: What I did to my toyota today?  (Read 52890 times)
Re: What I did to my toyota today?
« Reply #15 on: May 27, 2012, 12:52:11 AM »
Finished my oil cooler setup:
Audi V8 oil cooler
Greddy oil cooler sandwich plate w/built in thermostat
Black -10 AN lines and fittings
BIG thank you to Efrain for all the help.  I will try and get some pics up in the next couple days.  Been busy with work and trying to get the car ready for the upcoming event.
« Reply #16 on: May 27, 2012, 10:32:19 AM »
I finally started tearing the old one down.  Nothing big yet, mainly just interior and exterior stuff.
« Reply #17 on: May 27, 2012, 08:03:54 PM »
Put the track car on car dolly's so I can move the eye sore, at least to one side of the driveway.
Then cleaned their room
« Last Edit: May 27, 2012, 10:39:15 PM by SidewaysEightSix »
« Reply #18 on: May 29, 2012, 01:23:04 AM »
the installed my new lip
Zaxous
« Reply #19 on: May 29, 2012, 12:35:13 PM »
Installed hood pins that will be in place until I get a straight rad support and new hood from Deuce
Zaxous
« Reply #20 on: May 30, 2012, 02:29:19 PM »
Late last night I removed my old drivers seat and installed the evo 8 seat. It's infinitely more comfortable.
« Reply #21 on: May 30, 2012, 02:49:35 PM »
-tightened up all of her exhaust bolt
-topped off oil (I haz leak :(
-fashioned a pass. mirror blockoff out of some thin metal
-re-packed and torqued pass. side wheel bearing
-realized I really need new rear tires
 ;D
braide86
« Reply #22 on: May 30, 2012, 11:15:34 PM »
Took it for a drive out to the Florence exit past Gold Canyon and back to test the ride quality.
It was steady as she went. Looks like i will be taking her to work on Friday!
singleboost
« Reply #23 on: May 31, 2012, 10:13:40 AM »
I installed air conditioning  ;D  but then it would not turn on  :(
I'll be diagnosing that tomorrow.
Zaxous
« Reply #24 on: May 31, 2012, 08:05:15 PM »
Both radiator fans are running, so now I'm not worried about overheating. I just need to get that old turbo out now.
« Reply #25 on: June 07, 2012, 03:17:04 AM »
Fiberglassed all of the broken tabs of my plastic bumper pieces and put it all back on. Alligned my doors.
« Reply #26 on: June 07, 2012, 09:20:14 AM »
Removed my leaking water pump (thanks Aaron for the help).
Disassembled and cleaned said water pump.
Reassambled with RTV, let cure for 24hrs.
Reinstalled everything and filled with coolant last night.
So far no leaks, I will drive the car hard this weekend and see what happens.
« Reply #27 on: June 07, 2012, 07:37:14 PM »
-Finished stripping the dash I bought from Scott (thanks again).
-Prepped and Painted Dash.
-Mocked up fender flares and drilled small holes at hold points.
-Hammered wheel wells and waved at neighbors giving me bad looks.
-Soldered more 8 pieces on the megasquirt board
*did a double Irish Heel Clicker to mark stopping point until tomorrow*
braide86
« Reply #28 on: June 09, 2012, 10:18:59 AM »
I traded it for a motorcycle!
Anybody looking to buy one?
« Reply #29 on: June 09, 2012, 01:48:37 PM »
it's not Toyota :(
but I'm making a test pipe and straight pipe exhaust for my friends MX-5 Miata.
We are guesstimating via arm scale that we shaved over 10lbs.  Sill needs a little love and some hangers, just ran outta time. Less than $130 in material.
I think it sounds pretty good, but I have Proud Pappa syndrome so I could be being biased lol.  Maybe a little raspy in the top end.
http://youtu.be/NxwFHXW86Qg
