Author Topic: 20V Purple Top!  (Read 40937 times)
20V Purple Top!
« on: February 29, 2012, 02:16:14 AM »
With the new board comes a new build thread.  I never update my build threads so bear with me as I track down build pics.  Below are a few shots of the car when I first got it and a mostly current parts list.
Under-hood:
1985 Toyota Corolla GT-S
20V BT motor
PASS Racing velocity stacks
Modified 280z airbox
Ultra spark plug wires
TOM'S oil cap
CF Radiator shroud
Mishimoto Civic radiator (now with a real mounting bracket!)
Buddy Club Spec II exhaust
Toysport header
Braille 11.5lb battery
Greddy thermostatic oil cooler sandwich plate
Modified Audi oil cooler
Suspension/Brakes:
Eagle 028: 15x8 -28
205-50-15 Federal 595 RSR tires
Greddy Type-S coil overs
D*Garage RCA's
C-pillar brace
X-drilled/slotted rotors front and rear
Stainless steel braided lines
20mm longer wheel studs
NST brake master cylinder stopper
Megan Lateral bar
Retrofitted MR2 front strut bar
Home made harness bar
Novustech 20mm spacers (rear)
T3 brake booster eliminator
AE71 brake booster heat shield
Porterfield R4-S brake pads
Body:
Hacked up front bumper
JDM Zenki front lip (slightly modified)
JDM Zenki rear bumper
Ricer tail lights
CF fenders
CF hood
CF headlight covers
CF eyelids
CF sideskirts
CF 40mm fender flares
MR2 sidemarkers
JDM Kouki corner lights
Interior:
Buddy Club bucket seat
NRG quick release hub
MOMO Gotham steering wheel
Project Mu shift knob
Takata 5pt harness
TOM'S pedals
CF shifter panel
CF radio cover
SK Engineering gauge cluster
Defi Link meter
Defi Oil Pressure and Temp gauges
Autometer Water Temp gauge.
« Last Edit: December 08, 2013, 05:30:03 PM by ZERO »
Re: 20V Purple Top!
« Reply #1 on: February 29, 2012, 02:20:19 AM »
Here are some pics of when I first got the car:
Efrain
Re: 20V Purple Top!
« Reply #2 on: February 29, 2012, 02:27:02 AM »
What brand is CF, looks like you have a lot of it :P
Allens13
Re: 20V Purple Top!
« Reply #3 on: February 29, 2012, 07:51:04 AM »
Now it's offical, the Purple Monster is on the new Board!
Re: 20V Purple Top!
« Reply #4 on: March 01, 2012, 01:51:51 PM »
Its to confuse the "simple" people.
Updated parts list.  More ish coming in this week for the 31st event.
Re: 20V Purple Top!
« Reply #5 on: March 02, 2012, 03:32:13 AM »
A few more older pics so of the car showing slow progress:
TOM'S pedals and oil cap.
Interior shot with the cracked dash the car came with.
99th and Northern meet, carbon fenders and Racing Heat rims.
First Radiator mount and old open ITB setup.
Side shot showing a dust plate/heat plate I made down at work.
JDM BUMPAAAAA
Yes I ziptied my carbon fenders on  :P
One last shot for the night.  A nice memory of a "Car Show" Woody and I went to.  I was the ONLY import there.  Now I know how a black man in Alabama feels.
Re: 20V Purple Top!
« Reply #6 on: March 02, 2012, 08:43:45 AM »
Your X-slotted/drilled broked?  Ruhroh
Re: 20V Purple Top!
« Reply #7 on: March 02, 2012, 12:40:15 PM »
Hahahaha, fixed.
Re: 20V Purple Top!
« Reply #8 on: March 15, 2012, 07:41:23 PM »
Updates on getting ready for the 31st:
Illegal Garage clutch, ARP flywheel bolts and resurfaced flywheel installed.  Thank you to NoMas, Sideways, Twincharger and Aqa for the help
New battery tie down welded up:
Set of Federal 595s arrived today:
5min later my 5th point strap for my Takata arrived:
Phunk Monkey
Re: 20V Purple Top!
« Reply #9 on: March 15, 2012, 08:08:54 PM »
I hope those tires are for the new wheels (although I thought they already had tires).  Or did you get rid of them already?
Reviving old threads since 1995
Re: 20V Purple Top!
« Reply #10 on: March 15, 2012, 08:19:21 PM »
These tires are to run in the front on my 2 Longchamps and whatever other 14x7s I decide to mount them on.  The 535s on my 15x9s are still holding up just fine.
Re: 20V Purple Top!
« Reply #11 on: March 18, 2012, 07:45:45 PM »
Newest pics of the engine bay showing off some new paint I tried out on the strut bar.
singleboost
Re: 20V Purple Top!
« Reply #12 on: March 27, 2012, 11:12:11 PM »
Sparkly and purple  8)
Re: 20V Purple Top!
« Reply #13 on: March 29, 2012, 01:02:44 AM »
Hahaha yes it is.  Welded in my side plates for my harness bar.  I will take the bar down to work and cut it to size tomorrow.  Also wired up my Defi Link control unit tonight.  Just waiting for my oil sandwich plate to arrive so I can hook up the sensors.
Re: 20V Purple Top!
« Reply #14 on: April 15, 2012, 02:04:57 AM »
I like this pic so I shall throw it in here as well as some more updates:
Defi Link unit along with oil pressure and temp gauges are all wired in and worked great on the track.
Waiting to hear back from a guy and I will be purchasing water temp, EGT and a tachometer.  The set comes with an extra defi link unit if anyone wants it.
Also before the next NASA event at Firebird I should have a Mishimoto radiator in as well as an oil cooler setup.
