Author Topic: ae92 20v swap  (Read 4412 times)
ae92 20v swap
« on: September 04, 2012, 09:11:46 PM »
Does anyone have any personal experience with this?  I'm considering doing a blacktop swap (engine and trans.) into my 1991 corolla le 4 door.  The car is a 5 speed with a 4afe efi engine.
I searched around a bit but couldn't find anything definitive.  I know I'll need custom wiring, but I'm not sure what else.  Supposedly 4age's with fwd trans. will bolt right in, but I haven't confirmed this.  I'm also wondering about little things like axles, shift linkage, heater, power steering, throttle cable, etc., etc.
Any help is appreciated.  ;)
NoMasHondas
Re: ae92 20v swap
« Reply #1 on: September 06, 2012, 12:04:21 AM »
I do know your stock fwd trans will work, I put a 4afe block into my 86, and we all know 20v bolt up to t50. So yes a 20v will bolt up to your fwd trans, anything 4a will bolt to anything  4a or 7a. Ask Efrain about the wiring, I bought the 4afe out of the 89 corolla 4dr, he was 20v swapping. I'm sure he has lots of info.
« Last Edit: September 06, 2012, 12:06:14 AM by NoMasHondas »
Re: ae92 20v swap
« Reply #2 on: September 06, 2012, 09:10:46 PM »
I'm looking to do the 20v engine and trans.  I'm hoping my stock mounts would work with the 20v trans.  I imagine it bolts in, but I'm also curious about the peripherals and little things.
Unfortunately, a bearing inside my stock trans. has gone bad.  It's still drives but I have a vibration that's getting worse by the day so it's on borrowed time.  I've toyed with the idea of doing a swap for a while, and the situation might be an excuse to finally do it.
Re: ae92 20v swap
« Reply #3 on: September 06, 2012, 11:41:14 PM »
Talk to Efrain.  I'm willing to bet a fair deal that he can answer all these questions for you.
Re: ae92 20v swap
« Reply #4 on: September 08, 2012, 01:43:35 PM »
Throttle cable will need mod. axles would depend on if you go C series trans. obvious wiring harness needs mod. exhaust and Intake. Everything is super straight forward tho its a easy swap. Less involved than ae86 20v swap also IMO not too difficult to do.
Re: ae92 20v swap
« Reply #5 on: September 08, 2012, 05:20:15 PM »
Forgive my ignorance.  Is the c series trans. the stock 4afe trans., or a version of the stock 20v trans.?
Re: ae92 20v swap
« Reply #6 on: September 08, 2012, 09:04:30 PM »
Both... :P I will be more specific. I think your car has c50-52 trans. the one i was refering to is the c160. Its the 6 speed used with the blacktop and a version was available with lsd. look for 12c as the last digits on trans for lsd version. non lsd 12a is last digits.
leelee
Re: ae92 20v swap
« Reply #7 on: December 02, 2012, 06:49:05 PM »
im sure you could order engine and tranny together quite easily
Re: ae92 20v swap
« Reply #8 on: December 04, 2012, 10:48:55 AM »
That's what I'll probably do eventually. 6 speed trans. would be baller.
The idea is on hold for the moment.  The car still runs and drives although the sound of the bad bearing is obnoxious - I get a scraping and/or roaring sound depending on speed lol.  Plus I've been dumping way too much cash on the toy lately.
Re: ae92 20v swap
« Reply #9 on: December 31, 2012, 12:02:08 AM »
im looking into this as well since i would like a BT 20V on my 94 corolla daily. im getting a van pretty soon so im thinking on making my daily funner.
