Author Topic: Project: Tandem Me Maybe?  (Read 9874 times)
Re: Project: Tandem Me Maybe?
« Reply #45 on: June 07, 2013, 05:26:41 PM »
so YOU bought that fucking car!...... fuck, you beat me to it for 3 days... motherfucking luck reverting to how it used to be.
« Reply #46 on: June 28, 2015, 01:56:12 PM »
So I moved this one into the garage at my moms house.   Since pink car is basically finished, and the white car has a new engine to go in, I figured it's time to focus on the rental car.    I have some parts to acquire then this off season will hopefully have lots of pink car drifting and black car wrenching!
I now have another unknown Trans for it so hopefully one works.  Car has a full drivetrain now.  Needs wiring and fuel and a seat.   Suspension is 85% there.  Nothing special but plenty good enough for a missile/practice car
« Last Edit: June 28, 2015, 01:58:33 PM by SidewaysEightSix »
« Reply #47 on: July 03, 2015, 04:03:45 PM »
Washed the car inside and out.  Lots of nasty in there.
Compiling a list of parts needed and figuring out numbers to do what I said I would do with the pink car before I actually did what I did with the pink car.
It's like Deja Vu
This is how bad I want to door bang.  im building both cars lol
« Last Edit: October 25, 2017, 09:32:47 AM by SidewaysEightSix »
« Reply #48 on: July 04, 2015, 03:03:44 AM »
I can barely get one up n running, I dunno HTF u find time for um what is it now??? 3!!!!!! Good shit mang keep it up  8)
« Reply #49 on: July 04, 2015, 09:41:39 AM »
Spent a couple hours at my moms last night putting this thing under the knife.
Got the car two up in the front and pulled most of the suspension out.  Gonna sWap hubs onto my TRD/AGX struts.  Waiting on wheel bearings and bushings to come in.
« Last Edit: October 25, 2017, 09:27:42 AM by SidewaysEightSix »
« Reply #50 on: July 05, 2015, 09:51:19 PM »
 Picked up a another SR5 rear along with spare axles.  got tension rods and sway bars.  put in most of the front Prothane bushings over the weekend.  need to bring a puller to get the knuckles off so I can do the front control arms.  REALLY need hardware.
 parts order should get here this week and I can assemble the front struts/hubs.  next 20v comes out so I can further clearance the firewall and do new mounts and clean and prep the motor.
« Last Edit: October 25, 2017, 09:28:29 AM by SidewaysEightSix »
« Reply #51 on: October 23, 2017, 02:13:22 PM »
So I guess I'm back to doing something with this thing lol.
Picked up GTS fuel lines for it
Just ordered a fixed/manual Timing belt tensioner for the black top
Also ordered a Cusco engine/trans mount kit.
Firewall has been clearanced.
Power rack has been looped.
I'm considering hosting a tech day once I have some ducks lined up.   Those who wrench, drive.
It'll run at some point lol.  There's a video on my youtube channel that is very current in this car, dubbed Thyia.
« Last Edit: October 23, 2017, 08:19:14 PM by SidewaysEightSix »
« Reply #52 on: October 26, 2017, 08:27:11 AM »
Count me in.
Send me details...
Keegan
« Reply #53 on: October 26, 2017, 10:08:50 PM »
I'm interested. I don't know if mine will be running by then but I would like to put faces to screen names.
« Reply #54 on: November 03, 2017, 02:07:25 PM »
Motor mounts and tensioner arrived
Next on the list is a full spool for the sr5 rear ends
Also I need bolts.   So if anyone has a Toyota/ae86 bolt collection, I'll buy them from you.
Kyle has stock knuckles so I can replace the bent one we swapped off Andrews UZE72.  Orrr I can send them to Julian and get sent some Heat Maker knuckles back.  We'll see
I need to pull the white car out of the garage for a month or two I think.
« Reply #55 on: November 12, 2017, 08:20:46 PM »
Tech day yeahhh. Wouldnt mine seeing the old battle axe  8)
« Reply #56 on: November 17, 2017, 11:21:36 AM »
So I've pulled the black car into the middle of the garage and put the front in the air.
Bolted Up the GTS Front away bar.
Prothane bushings everywhere except Rack n Pinion.
Replaced the bent knuckle
Installed the Front Calipers and Braided Brake lines
Front Suspension has T3 camber plates, over AGX Adjustable Short Strokes and TRD 8k springs
Engine Bay is my next target.
« Reply #57 on: December 01, 2017, 08:49:38 PM »
Ended up skipping the engine Bay
But found the D-Max tails from Zeros car from when I put it into the wall....   they are now on the missile.
Also I put my old "setup" on the rear.  RS*R rear lowering springs with KYB GR2 shocks.
A lot of work to go, but there's a lot of free parts waiting in the shop.   By far this has been the most relaxed, most fun, build I've ever done
