Author Topic: 4AFE troubles in AE94  (Read 7332 times)
Re: 4AFE troubles in AE94
« Reply #15 on: August 24, 2013, 03:29:47 PM »
Valve cover is pimp!
« Reply #16 on: August 24, 2013, 03:39:01 PM »
thanks scott! i did it for him. i can spray up something for yours if you like. shoot me a text you got my number. if not PM me.
« Reply #17 on: August 27, 2013, 10:42:25 AM »
Yeah, Ricky did a nice job on it. Thanks again man!
Update: I replaced the ACV/VSV thing on the end of the manifold for one I found in the junk yard and it ran slightly but it still seems to have issues if the car is in drive/reverse, the brakes are pressed and the AC is one...
There's a valve with two vacuum hose fittings that is part of the same system with jb weld all over it, as if the nozzles broke off before, so I'm figuring it's likely to be still leaking or it's clogged.  It connects to the charcoal canister and then to the throttle body. Would this cause a rough idle under a load?
lol not sure why I ignored this before.... going to try replacing this next since it needs it anyways...
