Author Topic: Crono's F20 Swap!  (Read 48727 times)
errin
Re: Local mechanics that can swap an f20c
« Reply #15 on: November 08, 2013, 09:16:21 PM »
have you considered selling your car and buying one with a f20/f22 swap done already?   it would probably save you a few thousand dollars.    you can get a already swapped one for 7-8k on club4ag.
Crono0001
« Reply #16 on: November 08, 2013, 10:08:59 PM »
None that are nearby that I like.
Plus, I would also like to know the progression of the build.  That way, I know the car inside and out.
Porsche Boxster 986 3.8
Toyota Corolla AE86 F20C
Mazda Miata NA8C
theAngryMarmot
  • www.theangrymarmot.com
« Reply #17 on: November 10, 2013, 07:22:48 PM »
 Psssssh,
Why go high tech and modern?
Why not swap in an engine that is only slightly newer than the original, and produces significantly less power than the F20C?
That is right, swap in the mediocrity known as the BP from a Miata.
lol.
93 Red Miatar, 93 Black Miatar
95 Civic Coupe B16 , 95 Civic Hatch RaceCar
Crono0001
« Reply #18 on: November 10, 2013, 08:46:52 PM »
If I'm going to spend money, might as well go all the way :P
I've been getting a lot of advice from you guys (many many many thanks) about what I'm about to embark on
Most of it is in regards to rear ends, and how the GTS will probably give with that much horsepower
I've read that the MK2 Supra rear end fits.  What other options do I have?
Mazda Miata NA8C
nfelge
  • sport poop
« Reply #19 on: November 10, 2013, 09:12:15 PM »
you can weld the diff
please be nice to me
« Reply #20 on: November 10, 2013, 09:54:09 PM »
And then snap an axel. Plus welded diffs are not so good for daily driving...
« Reply #21 on: November 10, 2013, 10:14:11 PM »
i wish i had more free time, i love doing bastard swaps
« Reply #22 on: November 10, 2013, 11:40:12 PM »
Forgot to mention, Twincharger,
I have the GTS fuel tank and GTS fuel lines (from J.tin, many thanks).  Still need the wiring harness and rear axle.  The mounts I was going to buy from the link Efrain sent me.  I'll probably upgrade the brakes as well.
I have not yet purchased an S2k motor+tranny, or gauge cluster.  I want to know where I'm swapping first, AZ or CA.  I don't want to buy an ebay motor if I can avoid it.
If I remember right, the aluminum oil pan interferes with the ae86 crossmember. One of them needs heavy modifying.
« Reply #23 on: November 11, 2013, 09:52:13 AM »
^Both do. (pics from this thread http://forums.club4ag.com/zerothread?id=4007)  Like so:
« Reply #24 on: November 11, 2013, 10:24:31 AM »
Luckly for you I have a spare sub frame. The oil pan for the f20 is fairly bulky but I didn't know that had to be done. Is this because the installer wanted the motor as far back as possible or was this a unavoidable event?
« Reply #25 on: November 11, 2013, 11:00:01 AM »
I have no idea if it's always necessary, but it seems to be required when using the jsp mount kit.
« Reply #26 on: November 11, 2013, 11:23:27 AM »
Now I feel bad! I totally forgot about Dan! He does great work. Check his ae86 out, it's the nicest one in Az. And doesn't have a toyota motor either lol.
« Reply #27 on: November 11, 2013, 11:25:23 AM »
Psssssh,
lol.
I really hope your joking about the Bp swap. There's 10 motors I can think of swapping before I would do that.
« Reply #28 on: November 11, 2013, 11:34:25 AM »
That makes it easier to break lol! And don't weld your dif or go full spool unless you want it to go sideways every time you turn. I would know I have mine welded.
theAngryMarmot
« Reply #29 on: November 11, 2013, 12:39:27 PM »
Psssssh,
lol.
I was only half kidding. The BP Miata motor isn't a bad one. There are a ton of better ones - but for what you can get them for, how simple they are, and the huge aftermarket - there are many, many, more bad choices.
