Author Topic: any is300 fans? I'm lookin for ideas on engine swaps...aristo/supra..or na-t  (Read 12446 times)
Na 7m
Deff will give you a code for lack of speed sensor
What are your goals and what is your spending limit lol
1stGENis
I have 137, 000 miles on my is300. ...at 130, 000 I heat staightened the head, milled it, 3 angle valve job, head gasket,  water pump,  timing belt,  spark plugs,  front crank seal.....the head gasket blew ten days after I bought it. ...my goal is not outrageous..maybe 400-450hp...with a standard trans...I have the vvti 2jz-ge..I know my weak links are the rods and my auto trans.....so I'm thinkin arp head studs...non vvti rods..new rod and main bearings..cylinder hone..new piston rings. .the r154 conversion...and I should be very happy then...boosted with more fuel and a tune of course. ..
So....my question is....how much does an r154 trans go for and around how much does the conversion cost..to do it right....
Thx for all the support. ..I've been on other forums and they were not helpful
Sounds like your on the right track dude.
The trans it self varies quite a bit in price. If your lucky enough to find one in the yard(not likely with crazygay240 hording them all) you would only pay $150. If your buying one anywhere else I would expect anywhere from $400-$2000. But don't pay 2 grand that's ridiculous but I have seen them posted for that.
crazy white sileighty
I don't understand why everyone gets so upset at the fact that I have 7 r154s. I have 2 2jzgtes a 1jzgte a 1.5jzgte a 7mgte  and I am looking to get a third 2jzgte. The 7th is a spare ;)
I am not upset at all :) just call them like I see them. Props on having all of the r154 trans lol :p
Na 7m
holly hell. that alot of r's
1stGENis
@crazy white gay240...sell me a r154...and if u ever need any aluminium tig welding done, I can hook u up...or a.c. parts...I work for a major parts distributor...
SR20DET.
http://www.properimage.net/forum/showthread.php?318-SR20-DET-Toyota-Altezza-(is300)
Lighter than a 2J and 3SGE. Proven reliability and power. Very possible it will be cheaper than installing a 1J/2J and sourcing an R154 OR doing a 3SGE swap.
Think about it, all you will need is mounts and driveshaft besides the motorset.
You are welcome.
Hahahaha!!!!
Sr20 your own car already! Or did you decide to go 1uz now? I can't keep up anymore lol!
The motor currently in the car already makes the same power as a turbo sr20 red top. With the money it would take to upgrade the sr with bigger turbo, injectors, ecu he could just turbo the motor he already has. So I have to disagree completely with the sr swap into a IS300.
I do like the sr btw I might swap my s13 with one. So it's not that I am anti sr.
jimmyde
NA-T leave the auto alone and save for a complete 5spd swap if ya want. Also, read up on the diff... you might not be too happy on the free way. GL
Hahaha I just got another r154. That makes 8
Na 7m
i would rather shoot myself in the foot than put a sr20 a altezza........ even an is300..... 3s or go home ahahahaha just kiding but seriously fuck that noise 3s powns sr20
you sir are a faggot. sell me one you queer  :P
Brando
lol I just tired at one too... apparently he has plans for 7 of them :o
AdamP
SR20DET.
You are welcome.
I got the mounts if anyone needs them.
