Author Topic: 1990 toyota cressida  (Read 22984 times)
« on: December 26, 2013, 10:08:36 PM »
bought the car with:
z32 front 4 piston calipers
mk3 supra diff/lsd
jzx81 chaser front (missing the trim piece below the lights, half assed fenders)
nardi yachting steering wheel
leaky 1jzgte with r154 transmission
beat up 17x9 advan wheels
this heap is my daily, but i never leave anything alone
it currently needs a lot maintenance, and it all needs to be done when i can fit it or when i am not messing with the corolla.
it's gonna be boring for a bit.
just recently replaced both rear axles and rear bearings, it was so fun i didn't take pics.
the wiring job was a mess, i horrible horrible mess.
i guess the car was originally built in 2003.
so i guess there wasn't alot of info on the swap at that time., but whoever did the wiring liked to do extra work for some reason.
even tho the car runs fine, i decided to clean up the harness to make the car easier to work on.
here are the pics from todays fun.
pulled the intake manifold to make it easier to get to the harness rats nest.
this is the jdm harness which isn't too bad
here is half of the usdm harness that was hacked apart and repinned through a butchered ecu that had been turned into a jumper box
tomorrow, i will go through both harnesses and delete all the unnecessary wire and re pin it to get rid of the jumper box. super excited.
while the manifold is off, i am going to fix the haggard fuel line setup, make a braided clutch line and swap all the power steering lines to a/n with an alloy reservoir.
« Last Edit: December 26, 2013, 11:58:17 PM by haymaker »
Na 7m
Re: 1990 toyota cressida
« Reply #1 on: December 26, 2013, 11:33:53 PM »
I think I have seen this before  ???
« Reply #2 on: December 27, 2013, 12:05:22 AM »
It takes a lot of wires to make a JZ run.
BL=Boost Logic ?     Probably not.
« Reply #3 on: December 27, 2013, 06:12:10 AM »
I spy "a muthafuckin Rukkus" ha!
Na 7m
« Reply #4 on: December 27, 2013, 08:23:51 AM »
it has a chaser front end doesnt it!!!!!!! i swear it the chassida  :P
« Reply #5 on: December 27, 2013, 10:28:28 AM »
it doesn't take half as many as this car has, i'v already removes about 60' of wiring in these pics  :-\
yeah, chaser front. it's my daily so it's likely you've seen it around
toywagon82
« Reply #6 on: December 27, 2013, 12:16:31 PM »
I love this car.
Can i have it?
Lol
« Reply #7 on: December 27, 2013, 07:37:55 PM »
BL stand for Brian Lueck.
Aka the guy who started this website.. >_> (and jzxproject)
I think he started az240 as well. He is a computer guy, works for yahoo in Cali now.
I thought Gerald did a shitton of maintenance to it when he owned it? Even fixed the sunroof. I didn't read much of his jzxproject build.
« Reply #8 on: December 27, 2013, 07:52:13 PM »
Chassida.  sounds like something that stops you from getting laid.....
Na 7m
« Reply #9 on: December 27, 2013, 08:25:05 PM »
Seen it at the pavs a few times when the big guy owned it
« Reply #10 on: December 28, 2013, 12:25:37 AM »
dubsky, gerald upgraded the interior and fixed  a power steering line, he didn't really own the car long enough to do his usual battery of maintenance.
and i know who brian is, i am aware of the history of the car.
toywagon82, no
SidewaysEightSix, have you seen this heap, if i didn't have a girl already, this car would be like joining a monastery
crazy white sileighty
« Reply #11 on: December 28, 2013, 01:03:31 AM »
If Dan was to ever sell the car I am buying it
fasttoyo
  • Administrator
« Reply #12 on: January 31, 2014, 06:08:54 PM »
lol funny seeing that harness again.  as you can tell, 11 years ago i had no fucking clue how to wire.   it worked though.  i'll be watching this topic.
« Last Edit: January 31, 2014, 06:17:29 PM by fasttoyo »
fasttoyo
  • Administrator
« Reply #13 on: January 31, 2014, 06:10:24 PM »
btw, that mkiii lsd was pretty loose a decade ago, i am sure you pretty much have a open diff today.
« Reply #14 on: February 01, 2014, 01:36:22 AM »
yeah, that diff is pretty tired, my dog likes the cressida tho
