Author Topic: 1990 toyota cressida  (Read 24702 times)
Re: 1990 toyota cressida
« Reply #15 on: March 08, 2014, 01:39:24 AM »
how about some poor quality pictures!
new power steering reservoir, with a/n lines
had some really bad misfire issues that turned out to be oil leaking through the cam sensors into the actual plug and filling up with oil over time. i need to replace them so i immediately removed the rear subframe.
gonna install some subframe and diff bushings as well as reinforce the subframe a bit.
i'll get to those cam sensors one day.
« Reply #16 on: March 08, 2014, 08:42:39 AM »
don't forget the wheel bearings!
« Reply #17 on: March 08, 2014, 09:47:57 AM »
wheel bearings ar 3 months old
« Reply #18 on: March 17, 2014, 07:12:20 PM »
I had to read it twice. Rear subf.. Oh I see
« Reply #19 on: March 18, 2014, 09:44:53 PM »
is my storytelling failing?
« Reply #20 on: March 23, 2014, 09:16:00 AM »
No, its mindblowing.
Just need more stories.
What was it like in the seventies-early eighties?
« Reply #21 on: March 23, 2014, 09:36:35 AM »
i don't remember anything from then, my recollection starts in the late 80's early 90's mostly due to me trying to block out my childhood.
« Reply #22 on: April 05, 2014, 10:39:21 AM »
i tried to purchase serialnine subframe bushings, but they don't stock them and have no plans on having any available. so it was either go with technico racing at twice the cost or excessive. i went with excessive.
while the subframe is out i decided to fix it up a bit
the front diff mount holes were a little gnarly so i welded in a washer.
i am fairly new to mig welding, and it shows
added a bar on the back of the frame and a plate across the diff mount holes.
« Reply #23 on: April 05, 2014, 05:34:32 PM »
Your work looks good. Have you installed it yet?
« Reply #24 on: April 05, 2014, 07:32:04 PM »
Gnarly is right, Ho Lee Fook!!! Were the bolts loose or something? Came out good tho
« Reply #25 on: April 05, 2014, 07:55:52 PM »
no, i just ordered another set of axles, it's easier to put the whole thing in at once.
everything was tight and worked well enough, i just wanted it a little more stout.
« Reply #26 on: May 18, 2014, 09:53:57 AM »
can't wash off ugly.
the cute
« Reply #27 on: July 08, 2014, 11:12:18 AM »
spare R154 has been rebuilt with all marlin crawler/driftmotion parts.
now all i need to do is pull the trans and swap the shifter/housing/bell housing. but first i need to decide whether or not to put a new clutch in. i have no more money available for the cressida at the moment due to all of it being funneled to the corolla.
« Reply #28 on: July 08, 2014, 11:49:11 AM »
Ummm that's what credit cards are forrrr, duhhh  :P
Crono0001
« Reply #29 on: July 08, 2014, 01:59:33 PM »
The blight of having two projects :D
Porsche Boxster 986 3.8
Toyota Corolla AE86 F20C
Mazda Miata NA8C
